Hi,
sorry for being so quite about this project.
I'm working on it for quite a while, but first I wanted to make sure that I can get the critical parts to work which could have lead to failure like:
- the water system
- the arc generator circuit
- the Marlin feature for motion control
Now it can be used for sinker EDM or EDM drilling without a problem and I'm currently working on Wire EDM for precisely cutting metal parts.
I will post a description of all parts that I've got so far and if you are interested in testing it out or if you need more infos, let me know.
