Don't feel like committing to getting PCBs made and then soldering a handful of SMD components? How about trying it out on a breadboard first? After all, this is how it all started.
You'll need:
- 1x Arduino Nano
- 1x DS3231 RTC module
- 1x Addressable LED ring with 24 LEDs
- 2x 10 kOhm resistors
- 1x Pushbutton
- 1x Light dependent resistor (LDR)
- Breadboard, wires, soldering iron (for the LED ring as it doesn't come with anything connected to the pads)
Use the firmware from GitHub
Wiring diagram and a picture of what you can expect to get:
mihai.cuciuc
