Doesn't work on linux. Udev strikes again. udev helper things:
sudo udevadm control --reload-rules
sudo udevadm trigger
journalctl -f
udevadm monitor --environment
udevadm info -q all -a /sys/devices/pci0000:00/0000:00:1d.0/usb2/2-2
udevadm info -q all -a /dev/hidraw1
sudo udevadm control --log-priority=dubug
run udevadm monitor --environment and re-plug:
stephen@AO751h:~$ udevadm info -q all -a /dev/hidraw1
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
looking at device '/devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:1A86:E041.000E/hidraw/hidraw1':
KERNEL=="hidraw1"
SUBSYSTEM=="hidraw"
DRIVER==""
looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:1A86:E041.000E':
KERNELS=="0003:1A86:E041.000E"
SUBSYSTEMS=="hid"
DRIVERS=="hid-generic"
ATTRS{country}=="00"
looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0':
KERNELS=="2-2:1.0"
SUBSYSTEMS=="usb"
DRIVERS=="usbhid"
ATTRS{authorized}=="1"
ATTRS{bAlternateSetting}==" 0"
ATTRS{bInterfaceClass}=="03"
ATTRS{bInterfaceNumber}=="00"
ATTRS{bInterfaceProtocol}=="00"
ATTRS{bInterfaceSubClass}=="00"
ATTRS{bNumEndpoints}=="01"
ATTRS{supports_autosuspend}=="1"
looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2/2-2':
KERNELS=="2-2"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{avoid_reset_quirk}=="0"
ATTRS{bConfigurationValue}=="1"
ATTRS{bDeviceClass}=="00"
ATTRS{bDeviceProtocol}=="00"
ATTRS{bDeviceSubClass}=="00"
ATTRS{bMaxPacketSize0}=="8"
ATTRS{bMaxPower}=="100mA"
ATTRS{bNumConfigurations}=="1"
ATTRS{bNumInterfaces}==" 1"
ATTRS{bcdDevice}=="1000"
ATTRS{bmAttributes}=="80"
ATTRS{busnum}=="2"
ATTRS{configuration}==""
ATTRS{devnum}=="12"
ATTRS{devpath}=="2"
ATTRS{idProduct}=="e041"
ATTRS{idVendor}=="1a86"
ATTRS{ltm_capable}=="no"
ATTRS{maxchild}=="0"
ATTRS{quirks}=="0x0"
ATTRS{removable}=="unknown"
ATTRS{rx_lanes}=="1"
ATTRS{speed}=="12"
ATTRS{tx_lanes}=="1"
ATTRS{urbnum}=="14"
ATTRS{version}==" 1.10"
looking at parent device '/devices/pci0000:00/0000:00:1d.0/usb2':
KERNELS=="usb2"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{authorized_default}=="1"
ATTRS{bDeviceClass}=="09"
ATTRS{bMaxPacketSize0}=="64"
ATTRS{bMaxPower}=="0mA"
ATTRS{bcdDevice}=="0504"
ATTRS{bmAttributes}=="e0"
ATTRS{busnum}=="2"
ATTRS{devnum}=="1"
ATTRS{devpath}=="0"
ATTRS{idProduct}=="0001"
ATTRS{idVendor}=="1d6b"
ATTRS{interface_authorized_default}=="1"
ATTRS{manufacturer}=="Linux 5.4.0-77-generic uhci_hcd"
ATTRS{maxchild}=="2"
ATTRS{product}=="UHCI Host Controller"
ATTRS{serial}=="0000:00:1d.0"
ATTRS{speed}=="12"
ATTRS{urbnum}=="207"
looking at parent device '/devices/pci0000:00/0000:00:1d.0':
KERNELS=="0000:00:1d.0"
SUBSYSTEMS=="pci"
DRIVERS=="uhci_hcd"
ATTRS{ari_enabled}=="0"
ATTRS{broken_parity_status}=="0"
ATTRS{class}=="0x0c0300"
ATTRS{consistent_dma_mask_bits}=="32"
ATTRS{d3cold_allowed}=="0"
ATTRS{device}=="0x8114"
ATTRS{dma_mask_bits}=="32"
ATTRS{driver_override}=="(null)"
ATTRS{enable}=="1"
ATTRS{irq}=="23"
ATTRS{local_cpulist}=="0-1"
ATTRS{local_cpus}=="3"
ATTRS{msi_bus}=="1"
ATTRS{revision}=="0x07"
ATTRS{subsystem_device}=="0x0244"
ATTRS{subsystem_vendor}=="0x1025"
ATTRS{vendor}=="0x8086"
looking at parent device '/devices/pci0000:00':
KERNELS=="pci0000:00"
SUBSYSTEMS==""
DRIVERS==""
Seems that the rule
KERNEL=="hidraw*", ATTR{idVendor}=="1a86", ATTR{idProduct}=="e041", MODE="0666"
doesn't catch vendor/product parameters. I guess I'll stick with
KERNEL=="hidraw*", MODE="0666", GROUP="plugdev"
stephengeorgewest
Hmm? I don't use KERNEL bur rather SUBSYSTEM. My rules look like:
# Set Group for STLink-2
and it works.SUBSYSTEM=="usb", ATTRS{idVendor}=="0483", ATTRS{idProduct}=="3748", GROUP="dialout"
Thanks, that got me to a working rule for this device.
I originally had:
SUBSYSTEM=="usb", ATTR{idVendor}=="1a86", ATTR{idProduct}=="e041", MODE="0666", GROUP="plugdev"
and that worked for WebUSB, which accesses /sys/bus/usb/devices/*, but I needed WebHID, I noticed the ATTR / ATTRS difference so I changed it to:
KERNEL=="hidraw*", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="e041", MODE="0664", GROUP="plugdev"
and it seems to work.
SUBSYSTEM=="usb", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="e041", MODE="0666", GROUP="plugdev"
Also seems to work. I guess the differences is between allowing all usb control, or just hidraw*. Now looking at the output of
I don't see any ATTR without the S. I guess it is different between the /dev/hidraw* and /sys/bus/usb/devices*?
udevadm info -q all -a /sys/bus/usb/devices/2-0:1.0
has ATTR without S, but only at the top level, and none of them are vendor/product. Maybe I was just wrong in the from the get go.
