Overview:
- milled 4 module DIN rail enclosure
- top shell with grey or transparent cover
- for EN50022 DIN rails
- pcb with 2x 20pole female pin headers to plug a Raspberry Pi Pico
- optional integrated voltage regulator (input voltage 9..35V via 2 way terminal block)
- breadboard / proto board for own circuits
- all GPIO pins are marked and placed beside the breadboard area
- 3x 2 way terminal blocks to connect external components to the breadboard
- removable protections for terminals
- Opening for Micro USB socket of the Pico on top side
Alexander Rau
