Three of the linear actuators mounted to a ceiling with universal joints can come together at a common spherical joint suspending an actuating claw. Small items dropped can be aided in their retrieval. Trusting pets can be engaged remotely.
A resilient strip (of tape measure fame) triad fed through centrally driven rollers extends a structure constrained by self spacing ribs
Hi, really glad to see this. I had a play with these tape measures for a linear actuator too. I was using velcro/hook and loop to keep them together, as the roller action at the base was good at separating velcro and it was good in the straight sections at keeping the metal strips fairly rigid.
