Thanks for now! Please check out the ongoing new revision!
04/13/2022 at 13:57 • 0 commentsThank you so much to everyone who followed and liked this project.
Even though this project is finished, the journey is far from over.
The project page for Revision 1 has been updated with lots of logs and I hope you will all check it out here: https://hackaday.io/project/184725-abn6502-sbc-r1-Anders
Revision 1 is now live on hackaday.io
04/05/2022 at 11:50 • 0 commentsI can proudly announce the project made it the hackaday.com blog right before it was officially completed and superseded by Revision 1.
https://hackaday.com/2022/04/05/wireless-bootloader-saves-you-from-swapping-rom-chips/
All my efforts will now be focused on the new project page - you're welcome to follow that too :)
r0 is dead! Long live R1!
04/04/2022 at 07:48 • 0 commentsGithub has been updated with R1 of my SBC.
https://github.com/AndersBNielsen/abn6502
Since this actually turned out to be a complete rerouting of the whole board, I finally got rid of the - now unobtainium - PMS171b, and the firmware also got quite an overhaul I'm finishing up this project and moving on... To R1!
R1 will get it's own project on hackaday.io because they are simply too different - naming-wise I'll just call it R1 :)Check out one of the upgrades here - as you see the board is quite different:
I'll post a final log here when R1 has it's own project page.
Driving WS2812B LED's was fun... What's next?
01/05/2022 at 15:36 • 0 commentsAs some people have noticed I managed to rainbow some WS2812B LED's with my SBC.
Since I'm writing a wireless bootloader(surprise!) I think I will take the rainbow code and move it to "userland" instead of keeping it as a permanent part of the ROM.. Or maybe I will keep the basic "send pixel" subroutines so the firmware will still reset LED's on boot and you can call subroutine addresses from userland by simply setting R G and B zero page locations.
Either way I don't feel code organization is my strong side and the current zero page layout can really use a manual defragmentation.
I always meant for my SBC to have a simple "monitor" firmware that is barely able to let the user type in assembly programs.
I have a feeling the upper limit of the firmware will be a(very) simple resident assembler + disassembler - typing mnemonics straight to RAM might be "fun".
As for hardware changes I still haven't had a chance to test the "VGA" output reset modification and I really want to switch out the 4 bit counters with tristate 8 bit counters ( 74HC590's should work.. Right?) so I only need '245's on 6502 side... And for now sadly the PMS171B since I can't tristate that either. That thing really has to go :)
Lot's of things to do and not much time to do them...
PCB Annotations added to silkscreen
10/30/2021 at 12:26 • 0 commentsI always tend try to get things into production fast. This has a tendency to involve limited redundant information - said another way: I don't add silkscreen information already present on the schematic.
I believe I've reached a point where I know another revision of this board is coming eventually , so I decided to add some silkscreen text - if nothing else, so I don't forget that the broken out data and address busses have LSB on the left when the VGA port is pointing away from you :)Note: The Gerbers.zip hasn't been updated this time - if you are about to send them off to manufacture, maybe replot them from Kicad :)
Video online!
10/30/2021 at 11:55 • 0 commentsYay! I finally pulled myself together and made a short video about my 6502 SBC :)
Untested fixes in r1
10/21/2021 at 15:33 • 0 commentsThe new revision on Github has a few differences to the last tested version.
On r0 pin 15 of U20 (Chip enable of the VGA signal) is connected to ground. On r1 it is connected to the inverted reset signal(through a spare inverter on U14) through a pullup resistor.
Technically this should make it possible to RC-delay the VGA output signal until the VRAM is cleared by code - instead of having random data in the blanking periods that could damage a real CRT screen.
If this was really ~1979 I would definitely implement the VGA blanking periods in hardware.
[FANFARE]
10/21/2021 at 08:56 • 0 commentsThe project files are now on Github!
This included Kicad board files
https://github.com/AndersBNielsen/abn6502 -
r0 photos uploaded
10/21/2021 at 07:45 • 0 commentsPhotos of my SBC have now been uploaded - on r0 traces have been cut and A14 bodged to the RAM OE.
Code cleanup complete
10/20/2021 at 13:34 • 0 commentsNot that I'm particularly proud of my 6502 assembly, but I just managed to remove enough stub code that it only does the bare minimum - and doesn't have half-written subroutines for things coming in the future.
I guess it's ready for github :)
