Update BlueIO firmware using RaspberryPi
This article will explain how to update a BleuIO dongle using a RaspberryPi.
Public Chat
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The BleuIO comes with a bootloader to allow you to update the firmware or flash your own application to the dongle. To flash the dongle, you will need an image file containing the new firmware or your own application and a host USB loader application.
You can download the latest firmware, and host USB loader from our getting started guide.
Read more about the process here at
https://www.bleuio.com/blog/details.php?id=1266&title=Update-BlueIO-firmware-using-RaspberryPi
