Hardware
The 1st generation of NekoInk has the following specs:
- Processing
- NXP i.MX6ULL, 900 MHz Cortex-A7 processor
- 512 MB DDR3L-1066 memory
- Display
- Support for EPD screens from 6" to 13.3"
- Up to 32 greyscale levels / 32768 colors (depends on screen and waveform)
- 40 pin connector for ED103TC1/ES103TC2/GDEW101C01
- 6 pin connector for capacitive touch screen (shared signal)
- Connectivity
- MicroSD slot for storage
- 1x USB Micro-B for USB Device and charging
- 1x USB Micro-AB for USB OTG
- 1x USB Micro-B for USB Serial terminal
- 16 pin GPIO expansion port
- Integrated WiFi and Bluetooth
- Power
- AXP209 PMIC with Lithium battery charger and coulomb counter
- Power consumption around 0.3W idling (TBD)
Additionally, a converter board will be available to adapt the following screens:
- 39 pin connector for ED060SC4
- 34 pin connector for ED060SC7/SCG/SCE/SCM/SCT
- 34 pin connector for ED060SCF/SCN/SCP/XC3/XC5/XC9/XD4/XD6/XH2/KC1/KD1
- 33 pin connector for ED097OC1/OC4/TC2
- 39 pin connector for ED133UT2
- 40 pin connector for ED078KC1/KH4/GDEW078M01/078C01
Software
T.B.D.
Operating System
Linux T.B.D.
Waveform
This project uses a human-readable waveform format (iwf, Interchangable Waveform Format) described below. Currently this could be converted into .fw format used by i.MX6/7 EPDC/EPDCv2. See GitHub for details.
User Application
T.B.D.
License
The design, unless otherwise specified, is released under the CERN Open Source Hardware License version 2 permissive variant, CERN-OHL-P. A copy of the license is provided in the source repository. Additionally, user guide of the license is provided on ohwr.org.
The waveform converting tool is licensed under GNU GPLv2+ due to use of Linux kernel source code.
The image viewer tool is licensed under MIT. stb library used in the image viewer is public domain.
Wenting Zhang
john bruno
DEVON
Arnov Sharma
Michele Perla
