Installation is pretty simple - assemble a Adafruit Macropad, then follow the installation instructions in the GitHub repository's README. You can be up and running in minutes!
Once the software is installed you can select from a pre-built macro page in the wiki or create one of your own - templates are supplied so you can send commands or keycodes with each button press or turn of the dial.
DeckerEgo
armin
Sven Gregori
mircemk
Michael O'Toole
