Some process docs about some work routines
x-python - 23.52 kB - 10/07/2021 at 19:47
falstad simulation
PCB needle method
Finally I have summarized all in a Blender script. (Added as files for this project)
This create a worm drive (screw and gear) and a nut if you only need screw and nut. You can adjust some usefully tolerances too.
Don't use the addon in your scene. Load this file in another empty scene.I still need to put a picture on addon to facilitate more comprehension.
The scene have a can of soda to have dimensions reference too.
Enjoy it ;)
Note: This need "Extra Objects" addon
http://www.valvias.com/prontuario-rosca-metrica-din-13.php?m=11
Linear pitch: 1.5mm
Tooths: 20
Adapt Pitch diameter multiplier to get Outside diameter (10mm)
Creating the screw
Creating the gear
Creating one screw nut
Creating the screw axis
Creating the gear axis
Sources:
https://www.metalmecanica-facil.mahtg.com/tsinfycor/calculador-tornillo-sinfin-y-corona.html
https://docs.google.com/spreadsheets/d/1aFcktbNmx7cTsuAU0JgZB2Xayx76sSm1ici_PpTlju8/edit?usp=sharing
CONF adjusting tolerances:
Reduce 10um gear axis diameter
Reduce 10um screw axis diameter
Down 10um nut tooth top (1.125mm to 1.115mm)
Up 10um nut tooth top (0.375mm to 0.385mm)
Note: Make the same for the nut tooths
Now join the axis tooths
and nut tooths
and gear axis
20 tooths = 1:20 (around 75um per 1.5mm step)
reductor multiplier :)
1.5mm/20 = 75um
75um/20 = 3.75um
3.75um/20 = 187.5nm
187.5nm/20 = 9.375nm
If I place more of these I could do a kind of clutch disconnecting 2 and 3 and connecting 1 and 4 when apply some movement of joystick. I will need to handle micro-things in 2D/3D for future projects.
View all 5 project logs
Myles Eftos
mbasecnc
haqnmaq
Marsupilami
Yes, delete it Cancel
You are about to report the project "PROCESS DOCS", please tell us the reason.
