The continuity tester uses an AtTiny85 Digispark board, one resistor (close to 50ohm) and one active buzzer. Also only needs one line of actual code (excluding pin settings) and is a nice starting project for using the AtTiny with total project cost about $2 (+postage).
Files are:
- Continuity.ino
