Assembly of the pump unit
A project log for M5Stack Color Maker
With this device, you can copy the color of an object or create a new color with your imagination.
airpocketAIRPOCKET • 10/12/2021 at 00:58•0 Comments
Attach the stepping motor to the pump case.
Attach the bearings to the rotor. There should be two bearings per arm of the rotor.
Attach the rotor to the shaft of the stepping motor.
Pass the tube between the bearing and the case, and cover it with the lid.
Insert the tubing into the end of the syringe. If you can't mount it directly, you can use a larger piece of tubing as a coupler.
Attach the syringe bracket to the case.
Attach the pump to the base and you are done.
Make five identical ones and attach them to the base and you are done.
