U24 ("SPAL") - the expansion bus interface logic
Pins 1 and 2 go low at the I/O space (A23 to A8 are high). A7-A1, R/W, and /LDS are basic 68000 signals.
The manual states that the memory map looks like this:
$FFFFC1 R/W ZDATA Read: Data from Z80.
Write: Data to Z80.
$FFFFC3 Read SCLRINT Clear 1616 interrupt.
$FFFFC3 Write SINTZ Interrupt Z80.
$FFFFC9 Read SRXRDY Bit 7 set if receive latch full.
$FFFFCB Read STXRDY Bit 7 set if transmit latch empty.
$FFFFCD Read ZCOMMAND Bit 7 set if contents of the receive latch
is a command.
$FFFFD1 Write SCOMMAND Write data to the data latch,
set SCOMMAND bit.
The PAL multiplexes SRXRDY and STXRDY onto SD7.
Basically the two processors communicate through two 8-bit latches.
This all looks pretty simple to implement.
The binary behaviour data seems wrong, because pin 18 is listed as an input when it should be an output.
So I just had a quick go at deducing the logic by reading the manual and the circuit.
Keith
