The pixels are a little off to the left of my TV screen, so I wondered if the CRTC was properly programmed for PAL TV. The CRTC registers are copied from a block of ROM defined in crtcint.c like so:
uchar crtc_tab[] =
119, /* Horizontal total: 15625 Hz line rate */
80, /* Horizontal displayed */
96, /* Hsync position */
10, /* Hsync width */
77, /* Vertical total: 312/4 - 1 */
0, /* Vertical total adjust */
50, /* Vertical displayed: 200/4 char lines */
63, /* Vsync position */
0, /* No interlace */
3, /* Max scan line address: 4 rows/char */
0x20, /* No cursor */
0, /* Cursor end */
0, /* Start address high */
0, /* Start address low */
(uchar)(CRTC_SAVE/256), /* Cursor register high */
(uchar) CRTC_SAVE /* Cursor register low */
The standard square-pixel resolution for PAL video is 768 × 576 at a sampling rate of 14.75 MHz.
This was not a common oscillator back in the 1980s, so Applix used 15 MHz derived from a 30 MHz master clock. They could have used the 29.4912 MHz baud rate generator frequency, which is only 0.03% out.
I bought some 29.5 MHz oscillators which can be halved to 14.75 MHz. This is exactly right for PAL video and very good for setting baud rates.
Using the online tool for calculating CRTC registers: https://mrboot.de/mc6845.php, select PAL-DVD and the following:
pixel clock = 14.75 MHz
columns per character = 8 pixel/character
rows per character = 4 lines per character
and we get horizontally:
front porch 1.6 µs = 3 chars = 1.63 µs sync length 4.7 µs = 8 chars = 4.34 µs back porch 5.7 µs = 11 chars = 5.97 µs total vsync 12.0 µs = 22 chars = 11.93 µs active video 52.0 µs = 96 chars = 52.07 µs ; 96*8=768 pixels total line 64.0 µs = 118 chars = 64.00 µs ; 15.625 kHz
and vertically:
visible lines 288 lines = 72 chars * 4 lines each =288 vertical front porch 8 lines 2 vertical sync length 8 lines 16 lines vertical back porch 8.5 lines 0 lines total lines 312.5 lines 78 characters + 0 lines VSYNC is 15.625 kHz HSYNC ideally 50 Hz is actually 50.08 Hz
but the computer screen is not a full TV-screen, so there are still 80 displayed characters (not 96) and 200 lines (not 288). (96-80)/2 = 8 off each side and (288-200)/2 = 44 off top and bottom. Well, I did a spreadsheet and to the best of my knowledge this is what the CRTC table should be:
uchar crtc_tab[] =
117, /* Horizontal total: 15625 Hz line rate (Exact for 29.5 MHz)*/
80, /* Horizontal displayed (unchanged) */
91, /* Hsync position (moves pixels 5 characters to the right) */
8, /* Hsync width = 4.34 µs (slightly shorter than ideal) */
77, /* Vertical total: 312/4 - 1 (unchanged) */
0, /* Vertical total adjust (unchanged) */
50, /* Vertical displayed: 200/4 char lines (unchanged) */
63, /* Vsync position (unchanged) */
// unchanged hereafter:
0, /* Cursor end */
The CRTC table begins at 51d872 hex. Only 3 bytes change
Original:
51D872 77 DB 119 ; Horizontal total: 15625 Hz line rate
51D873 50 DB 80 ; Horizontal displayed
51D874 60 DB 96 ; Hsync position
51D875 0A DB 10 ; Hsync width
Modified:
51D872 75 DB 117 ; Horizontal total: 15625 Hz line rate
; (Exact for 29.5 MHz)
51D873 50 DB 80 ; Horizontal displayed (unchanged)
51D874 5B DB 91 ; Hsync position (moves pixels right a bit)
51D875 08 DB 8 ; Hsync width = 4.34 µs
; (slightly shorter than ideal)The bytes are spread over two ROM chips, so the ROM address offset is 51D872/2 = 28EC39.
The chips are on a 128K boundary, so the offset from the start of ROM is just EC39.
In the Low byte ROM, the changes are thus:
0000ec30: 7875 3a25 203e 250d 0050 0a00 3f03 0000 Original
0000ec30: 7875 3a25 203e 250d 0050 0800 3f03 0000 ModsIn the High byte ROM, the changes are thus:
0000ec30: 2073 6d20 782d 2078 0a77 604d 3200 2000 Original
0000ec30: 2073 6d20 782d 2078 0a75 5b4d 3200 2000 ModsI modified the ROM chips and the display is much more central, with a 29.5 or 30 MHz oscillator.
Keith
