Remoticon 2 badge
DIY Badge for Remoticon.2
If you would like a badge for Remoticon.2, this project is for you. It's a design in KiCad, with a bit of space for you to add in whatever you would like to have on your badge (and maybe already have parts for), but still in a look that will make it be part of the visual identity of Remoticon.2
So, compared to a badge that are handed out at an in-person event, this will require a little bit of effort ahead of time. If you want to have a badge for the event, you will need to send if for production fairly soon.
This years color theme matches OSHParks purple PCBs very nicely, and the fine silkscreen details will come out great, as they use a high DPI printing technique.
The KiCad project includes a badge design with a grid of regular 0.1" spaced pads, but the idea is that you remove all those and add in some circuitry that you think would be cool to have on your badge. And with the current state of silicon parts supply, probably something you already have or at least have found in stock somewhere.
This is ment to to be a fun little extra thing, so no need to spend too long on doing the perfect design, but maybe try to remix something you did previously, or experiment with that little part that you never got to use and is just sitting there on the shelf.
The important part is having fun and sharing with each other.
remoticon.2.badge.micromod.zip
KiCad project files for flummers MicroMod Carrier board variant
Zip Archive - 516.03 kB - 10/25/2021 at 16:46
Download
remoticon.2.badge.micromod.gerbers.zip
Gerber files for flummers MicroMod Carrier board variant
Zip Archive - 408.95 kB - 10/25/2021 at 16:46
Download
remoticon.2.badge.micromod.gerbers.paste.zip
Stencil files files for flummers MicroMod Carrier board variant (back only)
Zip Archive - 2.11 kB - 10/25/2021 at 16:46
Download
remoticon.2 badge artwork files.zip
ZIP file with Adobe Illustrator file with layers and PNG exports for each PCB layer in black and white (used for import in KiCad)
Zip Archive - 1.67 MB - 10/12/2021 at 20:13
Download
remoticon.2.badge.kicad_pcb
KiCad project file (Kicad 5.99/nightly)
kicad_pcb - 2.32 MB - 10/12/2021 at 20:11
Download
View all 7 files
View all 2 project logs
david biscan wrote 03/19/2024 at 21:12 point
Hi, I know this project is a bit old but I have the board from DC (I think) a couple of years ago but I have no components to solder. Is there a place I can buy the component kit?
mrwho wrote 11/11/2021 at 00:26 point
I wounder, where did you find that RISC-V micromod board? The design looks official, but sparkfun has no such board on sale?
Thomas Flummer wrote 11/11/2021 at 06:39 point
I have designed and build those. Currently there isn't that much info out about it, but I'll have a Github repo up soon, if you want to make your own. I might also make a few more at set up a Tindie store, but I'm not there yet.
