Pop! OS is a computer operating system designed for STEM and creative professions who use computers to learn and create. Unleash your full potential with open source software that is both safe and dependable. We have a feeling you have a lot of it based on your outstanding interest.
Pop! OS is built for quick navigation, simple workspace organisation, and a fluid, efficient working. Your operating system should facilitate rather than hinder discovery.
Pop! OS may be coming to ARM devices with the release of version 21.10, however System76 has not verified this.
For ARM devices like the Raspberry Pi, there was a period when only lightweight operating systems were available. Why? Because previous ARM devices featured low-end hardware with little RAM and CPU, they were ineffective.
Everything changed when the Raspberry Pi 4 8 GB model targeted desktop users, and the Raspberry Pi 400 doubled down on that with the release of the Raspberry Pi 400.
Pop OS is coming to the Raspberry Pi shortly!
Jeremy Soller, System76's Principal Engineer and Pop! OS maintainer, recently released a teaser shot on Twitter. The image is essentially a terminal snapshot of Neofetch running.
https://t.co/OXg3Md0erk pic.twitter.com/ehfGXwtsBf
— Jeremy Soller (@jeremy_soller) September 28, 2021
On this front, Systm76 has provided no more information. If I had to guess, I'd think the forthcoming Pop! OS 21.10 release will include an ARM version for Raspberry Pi-like devices.
Following the release of Ubuntu 21.10, Pop! OS 21.10 should be available soon. All of this leads us to believe that Pop! OS will be available for Raspberry Pi devices this month.
This is a good thing, because Pop! OS is well-liked among programmers. This might lead to an increase in the number of developers utilising the Raspberry Pi as a development platform.
This is an exciting development for me. What are your thoughts?
Posts You May like:
- How to Immediately Upgrade to Windows 11
- A Secret Update for the Raspberry Pi 4 8GB
- Raspberry Pi Introduces a New Documentation Hub
- Quick start with ESP8266 based Pico WiFi HAT
- Capture local Real-Time Air Quality Data with Raspberry Pi Pico
- GitHub CLI 2.0 Is Now Available, With Extension Support
- Connecting Wi-Fi on Raspberry Pi Pico Become Easy
- How To Track All Devices with Raspberry Pi
- Make your own Raspberry Pi Image from scratch
- How to Send phone notifications Using Raspberry Pi Pico?
- Raspberry Pi Pico 4G/2G Expansion : Expectations vs. Reality
- Quick Example to Drive Servo Using Programmable I/O
- How to Use a USB SSD or Flash Drive to Boot a Raspberry Pi 4 / Pi 400
- Filter Ads by your Raspberry Pi Before they Reach your Devices
- A Raspberry Pi 4 Model A Launch 2022 - Eben Upton
- First-Ever 2G Expansion Board for Raspberry Pi Pico has Launched on Kickstarter
- Learn IoT "Internet of Things" with 24 lessons for Teachers and Students
- Quick Guide for Raspberry Pi Users: Raspberry Pi Terminal Commands
- Windows 11 on Raspberry Pi Devices in Easy Installation Guide
- Get Your Project Done by Raspberry Pi Approved Design Partners
- PiRelay 8 Smart Relay Board for Raspberry Pi - Kickstarter
- Tiny Round/Circular LCD Display Launched!
- Issue Fixed! USB Boot Ubuntu Server 20.04 on Raspberry Pi 4
- HC-SR04 Sensor with micro-ROS on the Raspberry Pi Pico
- Raspberry Pi Pico: ADC Sampling and FFT
- Using CircuitPython for RP2040
- How to Setup Pico RP2040 on Windows
- Using micro-ROS on the Raspberry Pi Pico
- LED Tricks Using The Raspberry Pi Pico
- The RP2040 Raspberry Pi Pico Meets LoRa
- Pico supports SD cards and FatFS
- How to connect a Raspberry Pi Pico to LoRaWAN
- 50 Raspberry Pi Hacks & Tips You Should Know
- How to Install Wi-Fi and Internet on a Raspberry...
