I realized that 5 boards is the same price as 10 boards when ordering from PCBWay. So I ordered 10 instead because maybe I could them as breakout boards or something. And then I realized that I probably should have put more features into the boards because everybody will order at least 10, so what do you do with the 5 extras? Since the boards are hardwired to jumper certain pins together, that makes it tricky to use it as a regular breakout. But the board's reset switch will work on any port that has the reset connected. And the LED will work on any port that has power and ground.
I thought maybe connecting some thermocouples to the paddle ports so I can do temperature monitoring of the hot chips on the board. Maybe I'll think of something else.
