Hack Chat Transcript, Part 2
A event log for Spatial AI and CV Hack Chat
Computer vision, in depth
dan-maloneyDan Maloney 12/01/2021 at 21:030 Comments
Brandon12:38 PM
Just like a trained safety personnel can look out for.
ump12:39 PM
to tag on to Dan's question, are there use cases being discussed/debated that are non-human task/automation centered? I don't have examples or inkling what other cases can be used for SpatialAI
Brandon12:39 PM
https://youtu.be/npiG-Dy7yQ4
YOUTUBE LUXONIS
Dan Maloney12:39 PM
So maybe an advanced security system that, instead of sensing doors or windows open and close with switches, watch for, say, someone climbing into a window.
Brandon12:39 PM
For example, fall detection and can be privacy-preserving.
Brandon12:39 PM
Yes, good example Dan.
Brandon12:40 PM
@Erik - can you find the machine safety demo and share it here too?
Erik12:40 PM
or to detect when someone is too close to an operative robot. Spatial AI can detect where robot hand is, and where person is, and measure distance between them, demo here: https://github.com/luxonis/depthai-experiments/tree/master/gen2-human-machine-safety#gen2-human-machine-safety
Brandon12:40 PM
Thanks!
Brandon12:40 PM
@ump - yes. There are all sorts of applications which are not about replacing humans.
Brandon12:40 PM
And many of the problems are just unsolved problems, which were thought unsolvable.
Brandon12:40 PM
One good example is having OAK-based sensors on fishing nets.
Ethan Waldo12:41 PM
Or produce Gcode on the fly for robotic arms
Brandon12:41 PM
To make a smart fishing net.
Brandon12:41 PM
To prevent bycatch. Which is just unsolved now.
Brandon12:41 PM
The only way bycatch is discovered is by bringing up the net - and discovering (with horror) all the dead endangered species that are in it.
Dan Maloney12:41 PM
Is that catching unintended species?
Brandon12:41 PM
Yes.
Brandon12:42 PM
With Spatial AI, you can get the species, size, and locations of all of them. Underwater and communciated like a 56k modem back to the ship (through sound transduction).
Brandon12:42 PM
So you can just pull the nets or move them when species that are too small (common problem) or are endangered (or both) are present.
RichardCollins12:42 PM
I am working on "spinal cord injury" currently. You need rigged 3D models of the person for exoskeletons. You need 3D imaging real time of nerve activity. You need 3D monitoring of muscles. If you use the existing muscles by stimulation you need the models of the target area, the fields used, and careful planning to keep a unique human balanced. It is almost all 3D.
ump12:42 PM
Cool applications! Thanks Brandon
Dan Maloney12:43 PM
There have to be significant problems with turbidity and general poor-visibility conditions underwater in most places. At least I'd imagine so
Brandon12:43 PM
Thanks! A bunch more applications are in the materials below as well @ump :
https://opencv.org/opencv-ai-competition-2021/
https://www.kickstarter.com/projects/opencv/opencv-ai-kit-oak-depth-camera-4k-cv-edge-object-detection/description
Great questions!
Thomas Shaddack12:44 PM
thought. megahertz-range ultrasound transducer array. augment the vision with 3d sonar.
Brandon12:44 PM
@Dan Maloney - yes, the built-in edge filter helps with tubidity.
Brandon12:44 PM
Brandon12:44 PM
Here is IPOZ using it in high turbidity on OAK-FFC-3P.
Brandon12:44 PM
And @RichardCollins that's super cool. 100% agree.
Erik12:44 PM
@RichardCollins our community has created a few great projects that use our devices for 3D pose estimation, eg this one: https://github.com/geaxgx/depthai_blazepose#inferred-3d-vs-measured-3d
Brandon12:45 PM
@Thomas Shaddack yes love that idea. IPOZ is doing similar with Sonar underwater and fusing them.
Brandon12:45 PM
Search "IPOZ" on here:
Brandon12:45 PM
KICKSTARTER OPENCV
OpenCV AI Kit - Lite (and Tiny)
Spatial AI Made Easy, Tiny and Affordable - From the Biggest Name in Computer Vision 7,988 backers pledged $1,028,843 to help bring this project to life. You'll need an HTML5 capable browser to see this content. OpenCV AI Kit - Lite (and Tiny)
Read this on Kickstarter
Brandon12:46 PM
We need to get that video uploaded to Youtube separately... for now I think that's the only place it is on the internet.
Dan Maloney12:46 PM
Ah, cool. I'd imagine other wavelengths of light might help too.
Brandon12:46 PM
Yes. IIRC 400nm is best wavelength.
Brandon12:46 PM
And we have cameras that work there.
Thomas Shaddack12:46 PM
What about extending it to panorama-like arrays? overlapping fields of vision, and we could get 360-degree spatial awareness around the vehicle.
Brandon12:46 PM
400nm best for underwater IIRC. There is dip in absorption there.
Erik12:47 PM
video of IPOZ here
Brandon12:47 PM
Oh thanks Erik~
Riley August12:47 PM
If you're looking for underwater rangefinders, we actually have some stuff in the pipeline, feel free to reach out to myself or Matteo. You're in the right ballpark for laser.
Ethan Waldo12:48 PM
What's the difference between the Oak-D and Oak-D-Lite?
Brandon12:48 PM
@Thomas Shaddack - yes, we have several customers who are doing panorama overlap. Project NorthStar is one and open source for XR/AR.
Erik12:48 PM
@Ethan Waldo here we explain it in details: https://docs.luxonis.com/projects/hardware/en/latest/pages/DM9095.html#oak-d-vs-oak-d-lite
Ethan Waldo12:49 PM
thanks
Brandon12:49 PM
Using OAK-FFC-4P
Brandon12:49 PM
Thomas Shaddack12:50 PM
random thought for cameras. use reflective optics instead of lenses. then we don't rely on the air-water refraction index difference, and can flood the entire assembly with optical silicone oil/gel. voila, no crushable hollow spaces, and no pressure hull needed. electronics (without hollow components like crystal cans...) can withstand immense hydrostatic pressures. trick used for stuff outside of the inner pressure hull of submarines.
RichardCollins12:51 PM
Thanks Eric and Brandon. Besides spinal cord injury there are millions needed assistance because of various kinds of paralysis. For the Internet Foundation I map global groups and then try to put the pieces together. ("spinal cord" "injury") OR "paralysis") has 40.8 Million entry points. I found that having a technology is pretty much useless, unless you map the people working on it, who needs it, and all the subsidiary groups and people affected. So I am listening to you talking as see all the groups trying to work on the same technologies. Hackaday.IO could be an incubator and work with all other similar and related efforts on the Internet. Sorry to interupt. I am reading what you are talking about and trying to note where it can be used. Imagine keeping market studies for every idea in the world, along with competitive and business intelligence reports.
Erik12:51 PM
@Thomas Shaddack I believe IPOZ are using really thin quartz glass in front of the cameras and have cameras flush to the surface of the glass (to minimize refraction)
anfractuosity12:52 PM
you can get lensless cameras, that use a fancy pattern rather than say pinhole/zoneplate, i can't seem to find them at the moment though
Erik12:56 PM
@RichardCollins in a sense it already is, bringing the opensource community together:)
Erik12:56 PM
@anfractuosity how would stereo disparity work in at such camera?
Brandon12:56 PM
https://www.youtube.com/watch?v=XS1FtWqXWQk
YOUTUBE OPENCV AI
Brandon12:57 PM
This might be of interest too @RichardCollins .
Brandon12:57 PM
And agreed great idea!
Dan Maloney12:59 PM
We're about an hour in now, which is where we usually like to give the host(s) a chance to bail and get back to work. So I'll say my official thank you to Erik and Brandon for stopping by today, and to everyone for the interesting discussion. Food for thought for me -- I can think of a couple of different applications for spatial AI that I'd like to try.
anfractuosity12:59 PM
@Erik just found the paper https://arxiv.org/abs/1509.00116 i'm not sure afraid
Riley August12:59 PM
Thanks for coming. I got a pretty good perspective on other people's hardware, and that's always good to have!
RichardCollins12:59 PM
Erik, "open source" OR "opensource" is 201 Million entry points. It is NOT an integrated whole on the Internet and in the real world. I know the reasons why and can bypass and map from the outside. But getting groups so they actually collaborate to create real results for real people and needs, is a lot different than a bunch of people just talking about the same thing. Thanks for the links.
Brandon1:00 PM
Thank you all!
RichardCollins1:00 PM
Thanks for the great ideas and methods!
Dan Maloney1:01 PM
Thanks everyone. I'll post a transcript in a few minutes, in case you missed any links.
