Hackaday.io Hackaday.io
Sign up Log in
homemade lab tools
homemade lab tools
3drobert3drobert
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 6
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
607
0
3
2
Team (1)
  • 3drobert3drobert
Join this project's team
  • dprobe-curvetracer
MISC
ongoing project
This project was created on 10/14/2021 and last updated 2 years ago.
Project Logs
Collapse
  • First steps with EDM
    3drobert • 07/14/2024 at 13:48 • 0 comments
    Using 555 to augment volts (15v to 80v, 1KHz)
    Spark capacitor = 100uF
    IGBT = FGH60N60 (IR2101 driver + two flyback diode 15SQ045)
    18F2550 for ADC (spark capacitor measures) and IGBT control (20us-ON 150us-OFF)
  • ​differential probe module
    3drobert • 10/22/2021 at 01:32 • 0 comments
    rapid prototype for the differential probe module with an OPAMP TL084CN as differential amplifier
  • I-V curve tracer
    3drobert • 10/14/2021 at 02:50 • 0 comments
    insulator:
    conductor:
    capacitor:
    inductor:
    forward diode:
    reverse diode:
  • tester
    3drobert • 10/14/2021 at 02:45 • 0 comments
  • shaker
  • emulsion ​spreader
    3drobert • 10/14/2021 at 02:19 • 0 comments
    ESC + PIC (PWM&ADC)
    WYE wiring
View all 6 project logs
Log In/Sign up to comment
Sign up with Github
OR
Open source test bench inspired by NI-CompactDAC
Project Owner Contributor
Open test bench
bastienBastien
Who will join me in producing it? https://ahtlab.com/
ESP32 SIM7600 4G LTE
aht-labAHT LAB
This module is a simple PoE module using W5500 from WIZnet.
Easy PoE and Ethernet modules
minermillerMinerMiller
Supplyframe DesignLab: 2023 Hackada…
Flexible, compact and beautiful prototyping framework
next.module
ruslanRuslan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "homemade lab tools", please tell us the reason.
Send message
Remove Member
