It can't be that hard right? Linux kernel has modules for G11/G510, it should fit in right?
Adding the joystick was simpler than I thought.
in probe
/* * The G13 has a thumbstick and 3 buttons. */ if (g15->model == LG_G13) { input_set_capability(input, EV_KEY, ABS_X); input_set_capability(input, EV_KEY, ABS_Y); /* 4 center values */ input_set_abs_params(input, ABS_X, 0, 0xff, 0, 4); input_set_abs_params(input, ABS_Y, 0, 0xff, 0, 4); input_set_capability(input, EV_KEY, BTN_TRIGGER); input_set_capability(input, EV_KEY, BTN_THUMB); input_set_capability(input, EV_KEY, BTN_THUMB2); }
and the event handler:
input_report_abs(g15->input, ABS_X, data[1]); input_report_abs(g15->input, ABS_Y, data[2]); input_report_key(g15->input, BTN_TRIGGER, data[7] & 0x02); input_report_key(g15->input, BTN_THUMB, data[7] & 0x04); input_report_key(g15->input, BTN_THUMB2, data[7] & 0x08);
Shows up in jstest-gtk:
Also remapping the joystick to a mouse works in https://github.com/sezanzeb/key-mapper.
G1: 01 7a 7c 01 00 00 00 00 G22: 01 7a 7c 00 00 20 00 00 Left of lcd button: 01 7a 7c 00 00 00 01 00 M1 01 7a 7c 00 00 00 20 00 M3 01 7a 7c 00 00 00 80 00 MR 01 7a 7c 00 00 00 00 81 MR (release) 01 7a 7c 00 00 00 00 80 G1 (after MR): 01 7a 7c 01 00 00 00 80 click bottom: 01 7a 7c 00 00 00 00 84 click left: 01 7a 7c 01 00 00 00 02 click stick: ?probably in byte7 next to left/bottom move stick: ?probably byte1/2
https://github.com/ecraven/g13/blob/master/g13_keys.cc seems to match
Read more »stephen@ao751h:~/Documents/projects/g13$ sudo evtest No device specified, trying to scan all of /dev/input/event* Available devices: /dev/input/event0: AT Translated Set 2 keyboard /dev/input/event1: Lid Switch /dev/input/event2: Power Button /dev/input/event3: Sleep Button /dev/input/event4: Video Bus /dev/input/event5: SynPS/2 Synaptics TouchPad /dev/input/event6: Logitech Gaming Keyboard Gaming Keys /dev/input/event7: PC Speaker /dev/input/event8: WebCam: Webcam /dev/input/event9: HDA Digital PCBeep /dev/input/event10: HDA Intel MID Mic /dev/input/event11: HDA Intel MID Headphone Select the device event number [0-11]: 6 Input driver version is 1.0.1 Input device ID: bus 0x3 vendor 0x46d product 0xc21c version 0x111 Input device name: "Logitech Gaming Keyboard Gaming Keys" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 656 (?) Event code 657 (?) Event code 658 (?) Event code 659 (?) Event code 660 (?) Event code 661 (?) Event code 662 (?) Event code 663 (?) Event code 664 (?) Event code 665 (?) Event code 666 (?) Event code 667 (?) Event code 668 (?) Event code 669 (?) Event code 670 (?) Event code 671 (?) Event code 672 (?) Event code 673 (?) Event code 674 (?) Event code 675 (?) Event code 676 (?) Event code 677 (?) Event code 688 (?) Event code 691 (?) Event code 692 (?) Event code 693 (?) Event code 696 (?) Event code 697 (?) Event code 698 (?) Event code 699 (?) Event code 700 (?) Properties: Testing ... (interrupt to exit) Event: time 1634308318.780218, type 1 (EV_KEY), code 696 (?), value 1 Event: time 1634308318.780218, -------------- SYN_REPORT ------------ Event: time 1634308318.974217, type 1 (EV_KEY), code 696 (?), value 0 Event: time 1634308318.974217, -------------- SYN_REPORT ------------ Event: time 1634308320.244265, type 1 (EV_KEY), code 697 (?), value 1 Event: time 1634308320.244265, -------------- SYN_REPORT ------------ Event: time 1634308320.436316, type 1 (EV_KEY), code 697 (?), value 0 Event: time 1634308320.436316, -------------- SYN_REPORT ------------ Event: time 1634308320.898140, type 1 (EV_KEY), code 698 (?), value 1 Event: time 1634308320.898140, -------------- SYN_REPORT ------------ Event: time 1634308321.088286, type 1 (EV_KEY), code 698 (?), value 0 Event: time 1634308321.088286, -------------- SYN_REPORT ------------ Event: time 1634308321.480297, type 1 (EV_KEY), code 699 (?), value 1 Event: time 1634308321.480297, -------------- SYN_REPORT ------------ Event: time 1634308321.654302, type 1 (EV_KEY), code 699 (?), value 0 Event: time 1634308321.654302, -------------- SYN_REPORT ------------ Event: time 1634308322.038312, type 1 (EV_KEY), code 700 (?), value 1 Event: time 1634308322.038312, -------------- SYN_REPORT ------------ Event: time 1634308322.238330, type 1 (EV_KEY), code 700 (?), value 0 Event: time 1634308322.238330, -------------- SYN_REPORT ------------ Event: time 1634308330.802539, type 1 (EV_KEY), code 691 (?), value 1 Event: time 1634308330.802539, -------------- SYN_REPORT ------------ Event: time 1634308330.932562, type 1 (EV_KEY), code 691 (?), value 0 Event: time 1634308330.932562, -------------- SYN_REPORT ------------ Event: time 1634308331.448373, type 1 (EV_KEY), code 692 (?), value 1 Event: time 1634308331.448373, -------------- SYN_REPORT ------------ Event: time 1634308331.550427, type 1 (EV_KEY), code 692 (?), value 0 Event: time 1634308331.550427, -------------- SYN_REPORT ------------ Event: time 1634308331.992437,...
Loading up logitech gaming software to set some color. get color (blue):
Setup Data bmRequestType: 0x21 0... .... = Direction: Host-to-device .01. .... = Type: Class (0x1) ...0 0001 = Recipient: Interface (0x01) bRequest: SET_REPORT (0x09) wValue: 0x0307 ReportID: 7 ReportType: Feature (3) wIndex: 0 wLength: 5 bRequest: 9 wValue: 0x0307 wIndex: 0 (0x0000) wLength: 5 Data Fragment: 070000ff00
blue:: 07 00 00 ff 00
red?: 07 55 ff 00 00
green?: 07 ff 00 00 00
white: 07 6e ff 5a 00 I guess color correction is done in logitech gaming software...
off: 07 00 00 00 00
macro keys are on endpoint 5, and packed into a single byte:
Setup Data bmRequestType: 0x21 0... .... = Direction: Host-to-device .01. .... = Type: Class (0x1) ...0 0001 = Recipient: Interface (0x01) bRequest: SET_REPORT (0x09) wValue: 0x0305 ReportID: 5 ReportType: Feature (3) wIndex: 0 wLength: 5 bRequest: 9 wValue: 0x0305 wIndex: 0 (0x0000) wLength: 5 Data Fragment: 0501000000
Success? partially
If I just add the device here it might just work...
Ok so, my current linux device is a lousy netbook from 2009. I don't want to type on that mini screen. VS-code-remote doesn't work with x86, but WinSCP + ssh might just be good enough.
So many red squiggles... To add some linux header libraries, it says I need to open a folder. Ok, it added a .vscode folder... edit include path, copied the header files to a folder, and put them in the right order:
${default} C:\Users\Stephen\source\src\linux-headers-5.14.0-2-common\include C:/Users/Stephen/source/include/x86_64-linux-gnu C:\Users\Stephen\source\src\linux-headers-5.14.0-2-common\arch\x86 C:\Users\Stephen\source\include C:/Users/Stephen/source/src/linux-headers-5.14.0-2-common/arch/x86/include C:/Users/Stephen/source/src/linux-headers-5.14.0-2-amd64/include C:/Users/Stephen/source/src/linux-headers-5.14.0-2-amd64/arch/x86/include/generated
I don't know if that is helpful... It says U8 isn't a type, and game_mode_enabled is a function? oh well. I'll just try putting in the VID/PID and treat it like a LG_G15 and compiling.
stephen@ao751h:~/Documents/projects/g13$ sudo insmod ./hid-lg-g15.ko [141992.481805] usb 2-1: USB disconnect, device number 6 [141993.497565] usb 2-1: new full-speed USB device number 7 using uhci_hcd [141993.688838] usb 2-1: New USB device found, idVendor=046d, idProduct=c21c, bcdDevice= 2.03 [141993.688879] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [141993.688896] usb 2-1: Product: G13 [141993.713546] hid-generic 0003:046D:C21C.0130: hiddev2,hidraw4: USB HID v1.11 Device [G13] on usb-0000:00:1d.0-1/input0 [142482.986330] lg-g15 0003:046D:C21C.0130: hidraw4: USB HID v1.11 Device [G13] on usb-0000:00:1d.0-1/input0 [142483.055391] input: Logitech Gaming Keyboard Gaming Keys as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/0003:046D:C21C.0130/input/input47 root@ao751h:/home/stephen/Documents/projects/g13# echo 0 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 128 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 255 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 64 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 0 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 255 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# echo 64 > /sys/class/leds/g15\:\:lcd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# cat /sys/class/leds/g15\:\:macro_record/brightness 1 root@ao751h:/home/stephen/Documents/projects/g13# echo 0 > /sys/class/leds/g15\:\:macro_record/brightness
The led's show up at /sys/class/leds/, dmesg shows it loaded, and echo 255 > /sys/class/leds/g15\:\:kbd_backlight/brightness changes it to green, setting the macro led's change backlight to full brightness. And finally evtest shows no input events.
It has an rgb color backlight, so maybe it should be treated like a LG_G510
Skip that line of code, recompile...
Read more »root@ao751h:/home/stephen/Documents/projects/g13# cat /sys/class/leds/g15\:\:kbd_backlight/max_brightness 255 root@ao751h:/home/stephen/Documents/projects/g13# echo 255 > /sys/class/leds/g15\:\:kbd_backlight/brightness root@ao751h:/home/stephen/Documents/projects/g13# cat /sys/class/leds/g15\:\:kbd_backlight/color #ffffff root@ao751h:/home/stephen/Documents/projects/g13# echo "#ff0000" > /sys/class/leds/g15\:\:kbd_backlight/color root@ao751h:/home/stephen/Documents/projects/g13# echo "#00ff00" > /sys/class/leds/g15\:\:kbd_backlight/color root@ao751h:/home/stephen/Documents/projects/g13# echo "#0000ff" > /sys/class/leds/g15\:\:kbd_backlight/color root@ao751h:/home/stephen/Documents/projects/g13# echo "#ff0000"...
