Physical design and print
A project log for Heating Controller
Tempted to call this FrankenHeatController or something, but this time round doing it a little bit better.
h3liosphanh3liosphan • 10/25/2021 at 21:48•0 Comments
So basically I'm terrible at designing housings for my electronic creations - things change mid project, the housing ends up being sub-optimal to outright disruptive - check out my FrankenFlight controller to see an example.
So this time round I decided to go the whole hog with Fusion 360 and mock it up in its virtual entirety. The 1st pic in the gallery is an indication of this. Leave NO stone unturned in your pursuit of modelling everything to reveal any fitment issues prior to 3d printing - and I think it paid off this time!
This is the heating controller body, bits of importance only - the black oblong is the boost button as measured - this is all from actual measurements.
This is the servo positioned accordingly to line up with the boost button -
Now the other bits are put in place, while positioning them I thought about wall clearance distances too.
This is the Raspberry Pi, as lifted from their own specs PDF sheet, really handy!
The board on the top left is the MOSFET breakout board (see future project log for details on this). This is to scale, but I've only boxed out the areas, the big block in the middle is just the protruding MOSFET package, very roughly scaled up to help avoid any interference.
I use different design files for each component, then create a main design project drawing and bring them in by just dragging them in from the project drawer on the left. This has the advantage that you can open the original drawing again, make changes, then update them on the main design drawing.
I position them roughly as required and adjust to fit.
After that I just box up the whole case around these components, also putting mounting points in place for the bits. For this I see zero reason to make it a design masterpiece, even a black oblong can be suitable and pretty attractive for something like this - didn't even use the bevel / fillet tool once!
And here's the lid -
Here you can see the slot for the USB cable to power the Pi, servo and everything - leave no stone unturned!
And this is everything in place -
It really helps to have done a lot of 3D printing as I have, and learned the various challenges printing such a model. Things to consider -
I think I've come on leaps and bounds at project housing design - here's a sneak peak at the end result (sans actuator arm, because I've not made it yet).
Yes I've left the lid on for now - saving the 'reveal' for later! I'm not exactly done yet tho - still need to -
