When I originally purchased the M5Stack Core2 AWS EduKit I noticed that you cloud choose a few different languages. Because the machine/deep learning part would be developed in python and I was comfortable with it I wanted to use python this would just make it faster to prototype and move on.
M5 UiFlow
So, M5 UiFlow is like a blocky web tool to develop with the M5, this IDE lets you drag and drop or you can write with python. It's pretty basic and startin to understand what the project requires I felt this was not going to work for me. The initial test with the LM393 proved that, the Mic Unit was not supported which meant I'd have to develop something to support it. After doing some initial testing with the internal mic I also found that python was not going to be a good fit here. Arduino was the next best thing as I had used it in the past so figured this would be an easier transition.
LM393 Mic Unit
I bought the mic sensor thinking I would be able to record audio with it. Boy was I wrong, after many failed attempts it was clear this was not possible. The purpose of the device is a sound sensor, which is still good in my case as this would reduce cycles listening for events, instead I should be able to use it to trigger the recording.
