Creating the best combination between simplicity and functionality
AAA.STEPI know these files are not adaptable. I wan't to make the design good for anyone without need to adapt it. Therefor the design are in this format until further noticestep - 28.62 MB - 10/20/2021 at 22:58 |
For now, only 2 axes are incorporated. Eventually 4/6 axes will be implemtned in the design. for electronics used a Arduino uno with standard example sketch Knob only edited for two analog and to pwm channels. With 5V powering the board and servo's
