After doing object localization and tracking, we need to detect the gesture made using the object. The gesture needs to be simple so that it is efficient to detect. Let's define the gesture to be circular motion and then try to detect the same.
i) Auto-Correlated Slope Matching
Generate ’n’ points along the circumference of a circle, with radius = r
Compute slopes of the line connecting each point in the sequence,
Generate point cloud using any of the object localization Methods above. For each frame, add the center of the localized object to the point cloud.
Compute slopes of the line connecting each point in the sequence.
Compute correlation of slope curves generated in the above steps.
Find the index of the maxima of the correlation curve using np.argmax()
Rotate the point cloud queue by index value for the best match
Compute circle similarity = 1- cosine distance between point clouds
If correlation > threshold, then the circle is detected and alert triggered.
Upon implementation, the above algorithm is found working. But in practice, the distance between the localized points varies based on rotation speed and FPS. Another neat and simpler solution would be to use Linear Algebra to check whether the movement of points is convex or concave.
ii) Concavity Estimation using Vector Algebra
If all the vectors in the point cloud is concave, then it represents circular motion.
Compute the vectors by differencing adjacent points.
Compute vector length using np.linalg.norm
Exclude the outlier vectors by defining boundary distribution
If the distance between points < threshold, then ignore the motion
Take the cross product of vectors to detect left or right turns.
If any consecutive value has a different sign, then the direction is changing. Hence, compute a rolling multiplication.
Find out the location of direction change (where ever indices are negative)
Compute the variance of negative indices
If all rolling multiplication values > 0, then motion is circular
If the variance of negative indices > threshold, then motion is non-circular
If % of negative values > threshold, then motion is non-circular
Based on the 3 conditions above, the circular gesture is detected.
From the experiments, it became clear that we can use Object Color Masking (to detect an object) and use efficient algebra-based concavity estimation (to detect a gesture). If the object is far, then only a small circle would be seen. So we need to scale up the vectors based on object depth, not to miss the gesture. For the purpose of the demo, we will deploy these algorithms on an RPi with a camera and see how it performs. Now let's see the gesture detection mathematical hack as code.
for i in range(1 , len(pts)):
if pts[i - 1 ] is None or pts[i] is None :
continue
thickness = int(np.sqrt(args["buffer" ] / float(i + 1 )) * 2.5 )
cv2.line(frame, pts[i - 1 ], pts[i], (0 , 0 , 255 ), thickness)
isCirclePts = [p for p in pts if p is not None ]
if (len(isCirclePts) > 30 ):
vectors = [np.subtract(t, s) for s, t in
zip(isCirclePts, isCirclePts[1 :])]
vectors = [vector for vector in vectors
if np.linalg.norm(vector) > 5 ]
determ = [np.linalg.det([s, t])
for s, t in zip (vectors, vectors[1 :])]
directionChange = [determ[i] * determ[i + 1 ]
for i in range (len(determ) - 1 )]
if len(directionChange) < 10 :
alarmTriggered = False
continue
