I'm going to start with just a very simple mechanical design, just a PCB with the switches on both sides. I can think about improvements if the basic idea proves workable. So after compiling the very latest version of Fritzing (the appimage they released doesn't work on my system), I went to work and created this:
Yes, the traces have right angle bends. I don't care. This is a prototype. I can clean it up some other time.
I also added a joystick and a d-pad on the front side, for those moments when you are not typing. The USB socket is on the bottom, because that's where many devices have their socket as well — you can use a short OTG cable to connect them.
