The goal of this project was to create a circuit that can modulate the intensity of a 12V lamp with a line audio input and a microphone input. It should also be able to drive a loudspeaker. Both the Loudspeaker and lamp will be put into a Halloween pumpkin. This should allow me to place the pumpkin in front of my house and talk remotely via the pumpkin (as if the pumpkin was talking). Additionally, I need to hear the people outside to interact with them. For this, I also head to design a microphone preamp with AGC (Automatic gain control). The goal was to implement everything with analog circuits, and even without using integrated circuits (ICs). So I built everything from scratch just with undead tech from the past.
Details
Here you can find a video in which I walk you through my project.
Files
Main_Control_Assembly_Schematic_v01.pdf
Schematic of the Microphone Main Assembly
Adobe Portable Document Format -
53.98 kB -
10/26/2021 at 14:24
