So I figured out the display problem – I connected the (unused) reset pin to the camera's master clock pin by mistake, so the display was being reset at 16MHz... After fixing that, I finally got an image on the screen:
That... doesn't look like any swapped pins. To my untrained eye it looks like simply empty unintialized memory. Could it be that it "works" in the 16MHz mode simply because it does nothing? I tried switching it back to 20MHz, and now I'm getting a suspicious exception:
Traceback (most recent call last): File "code.py", line 45, in TypeError: unsupported bitmap type
So it looks like the bitmap type changes depending on the clock frequency? How does that even make any sense? Madness!
