Circuit diagram
The 25LS2538 chip is somewhat like a 74LS138, but also able to assert all eight outputs at once. No longer made or commonly available. The Elektor design replaced it with a fast 32-byte PROM (82S123). It could also be replaced with a PAL16L8 chip.
Original board:
2017 reproduction:
Has a phono video output socket and a modern crystal oscillator module.
