Just finished to assemble the prototype of the A/V board.
![](https://cdn.hackaday.io/images/3165951636767503919.jpg)
I was able to reuse the trimmer from the original modulator board, but it was necessary to bend the leads of the inductor and the trim-pots
![](https://cdn.hackaday.io/images/9284101636767724777.jpg)
I have already updated the board layout to accommodate the alternate footprints for the trim pot, the inductor and also the trimmer. I should print the board on paper to do a tryout before uploading the sources to github
![](https://cdn.hackaday.io/images/632491636767748111.png)
It was not possible to have an alternate jack. I should release 2 more versions for alternate types of 3.5mm jacks.
