It would be only a temporary solution.
The screw left is just for fixing.
The screw buttom right is for adjusting the blowing rate outside.Fastening it would make pressure higher.
The screw mid-right is nothing for right now.
The tune top connected to the pressure meter module.It's low-cast.
I'll update all BOM maybe in next version.
(Sorry for my LAZY head)
It's more clear now ! The "+" junction instead of a "T" one is just because it's easier to clean the 3d print. Or to place the real part inside a 3d printed shell.
I do like the fact that the sensor is upside and the saliva should go down. Good work !
(Plus the rest ;-) all the project look great !)
