Based on the PPMC-101C controller and L298 high-current driver
Arcom_J105_STMC_manual.zipManual, and data sheets for PPM101C and L298Zip Archive - 5.46 MB - 09/03/2022 at 15:16 |
ST_L298_datasheet-revision-5.pdfAdobe Portable Document Format - 1.41 MB - 05/05/2024 at 21:41 |
The STMC uses an intelligent LSI controller which provides all the functions required to drive a stepper motor without intervention from the host computer. In addition, the STMC contains a 2 amp 4-phase driver IC with heatsink, to produce a complete stepper drive module on a single Eurocard. The STMC accepts initialisation data and commands over the STEbus; initialisation data include motor type (3, 4 or 5 phase), starting and maximum pulse rates and number of pulses while accelerating. The STMC can calculate acceleration and deceleration rates, and will accept 8 main commands, including accelerating motion, constant speed motion and position up to 16,777,216 steps, optionally controlled by limit switch inputs, emergency stops and single stepping. In addition to 6 limit and control inputs, there are 8 general purpose TTL inputs and 8 buffered TTL outputs, all on a standard signal-conditioning connector.
0.5A typical at 5V
