The schematics are exactly the same with which I made the LibreServo v2 PCBs but with the texts corrected in position so they read better.
In previous posts as you can read in the article of the first LibreServo test board and in the conclusions of the second LibreServo test-board, the LibreServo changes were massive in each and every aspect. Virtually every component was overhauled and moved to a two PCB, four-layer design.
The result is as seen below, in addition, I have uploaded the design files to the LibreServo Github in the PCB folder.
An interactive version of the photos is available on the LibreServo website.
![LibreServo v2 Schematic LibreServo v2 Schematic](https://cdn.hackaday.io/images/9370031655570534556.png)
![Top & Bottom Top & Bottom](https://cdn.hackaday.io/images/7101541655570621954.png)
![Top Top](https://cdn.hackaday.io/images/4126911655570646746.png)
![Bottom Bottom](https://cdn.hackaday.io/images/7172961655570696534.png)
![Middle Bottom Middle Bottom](https://cdn.hackaday.io/images/2629751655570657516.png)
![Middle Top Middle Top](https://cdn.hackaday.io/images/3468921655570682762.png)
