Features & Specifications
- Atmel SAM D21 ARM Cortex-M0+ 48 MHz chip with 256KB Flash and 32KB SRAM
- Texas Instruments DRV8835 Dual Low-Voltage H-Bridge IC
- RGB LED
- Color coded terminal blocks for easy connectivity
- Standard 10-pin JTAG header broken out
- SPI header broken out
- Reverse polarity protection for power supply
- 12 V max power supply, 1.5 A current per H bridge
- Shipped with Arduino Zero bootloader for easy programming
Mahesh Venkitachalam
Kyle Rector
Wiktor Gonczaronek
Luke J. Barker
