An example for a node red implementation:
in Home assistant I've added a dropdown under "helpers":
with that in place, I can select between "manual" which simply does only what is selected on the air purifier or on HA (on/off, fan speed), "automatic" which uses air quality measurement as a criteria for on/off and fan speed or "time" which turns the AP on and off at a specific time at a specific fan speed.
here is the node:
"id": "0bdc4f11ed52dc5d",
"type": "tab",
"label": "Air Purifier 3",
"disabled": false,
"info": "",
"env": []
"id": "5e0fa840110275e8",
"type": "api-call-service",
"z": "0bdc4f11ed52dc5d",
"name": "on/off",
"server": "1bb0d825.3e7398",
"version": 3,
"debugenabled": false,
"service_domain": "switch",
"service": "toggle",
"entityId": "switch.air_3_on_off",
"data": "",
"dataType": "jsonata",
"mergecontext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 970,
"y": 820,
"wires": [
"ba87b75e6fefc6fe"
"id": "d08272d7bfb1789e",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "10",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 190,
"y": 120,
"wires": [
"7ce007c55044a93b"
"id": "32d95505345eeb3c",
"type": "switch",
"name": "switch on: \\n <10, <=20, <=50, >=100",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "lt",
"v": "10",
"vt": "num"
"t": "lte",
"v": "20",
"vt": "num"
"t": "lte",
"v": "50",
"vt": "num"
"t": "gte",
"v": "100",
"vt": "num"
"checkall": "false",
"repair": false,
"outputs": 4,
"x": 170,
"y": 960,
"wires": [
"69d3c175ae98a9a6"
"228bd948a665d7bc"
"d630f8370ece3b7e"
"805c6911af7286e6"
"id": "8758ba24542abccb",
"type": "api-current-state",
"name": "get measurement \\n 10pm sensor",
"version": 2,
"outputs": 2,
"halt_if": "0",
"halt_if_type": "num",
"halt_if_compare": "gte",
"entity_id": "sensor.particulate_matter_10_0um_concentration",
"state_type": "num",
"blockInputOverrides": false,
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"x": 210,
"y": 580,
"wires": [
"32d95505345eeb3c"
"id": "69d3c175ae98a9a6",
"type": "change",
"name": "change to 1",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "1",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 390,
"y": 900,
"wires": [
"6d0cd96036706e97"
"id": "228bd948a665d7bc",
"type": "change",
"name": "change to 2",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "2",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 390,
"y": 940,
"wires": [
"6d0cd96036706e97"
"id": "d630f8370ece3b7e",
"type": "change",
"name": "change to 3",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "3",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 390,
"y": 980,
"wires": [
"6d0cd96036706e97"
"id": "6d0cd96036706e97",
"type": "rbe",
"name": "",
"func": "rbe",
"gap": "",
"start": "",
"inout": "out",
"septopics": true,
"x": 570,
"y": 960,
"wires": [
"6f75c4d6d13132f8"
"id": "6f75c4d6d13132f8",
"type": "switch",
"name": "",
"rules": [
"t": "eq",
"v": "1",
"vt": "num"
"t": "eq",
"v": "2",
"vt": "num"
"t": "eq",
"v": "3",
"vt": "num"
"t": "eq",
"v": "4",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 4,
"x": 670,
"y": 840,
"wires": [
"93457cb56bc2ea42"
"51960ae7dc52dc95"
"2c3c05e44a952fd5"
"29d971730bab8ff5"
"id": "7e23ab4e672858d1",
"name": "on/off",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 970,
"y": 760,
"wires": [
"43a9eb74610ec9d1"
"id": "93457cb56bc2ea42",
"name": "if off",
"version": 2,
"outputs": 2,
"halt_if": "off",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "binary_sensor.airpurifier3",
"state_type": "str",
"value": "",
"property": "data",
"value": "",
"x": 830,
"y": 760,
"wires": [
"7e23ab4e672858d1"
"id": "dfeaa6d4edd5423e",
"name": "on/off",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 970,
"y": 900,
"wires": [
"2946f6aada43ac55"
"id": "cc9c66af89230026",
"name": "fan",
"version": 3,
"entityId": "switch.air_3_fan",
"data": "",
"mergecontext": "",
"queue": "none",
"x": 1310,
"y": 900,
"wires": [
"ee962ecd5962b9b5"
"id": "7ce007c55044a93b",
"name": "operation mode",
"version": 2,
"outputs": 2,
"halt_if": "manual",
"halt_if_compare": "is_not",
"entity_id": "input_select.master_bedroom_air_purifier",
"value": "",
"property": "data",
"value": "",
"x": 200,
"y": 300,
"wires": [
"d4cd761f8f6de816"
"id": "805c6911af7286e6",
"type": "change",
"name": "change to 4",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "4",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 390,
"y": 1020,
"wires": [
"6d0cd96036706e97"
"id": "7e3cfd2c33c74f5c",
"name": "on/off",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 970,
"y": 1120,
"wires": [
"327d0dc8de88dfd4"
"id": "faa5957d77558406",
"name": "fan",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 1270,
"y": 1120,
"wires": [
"509d7e93e7c0b6a4"
"id": "ffd89851cdcfb19e",
"name": "fan",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 1550,
"y": 1120,
"wires": [
"f88e5d8d8eeed8d7"
"id": "509d7e93e7c0b6a4",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "1",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"outputs": 1,
"x": 1400,
"y": 1120,
"wires": [
"ffd89851cdcfb19e"
"id": "2946f6aada43ac55",
"type": "delay",
"name": "",
"timeout": "1",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"outputs": 1,
"x": 1140,
"y": 900,
"wires": [
"cc9c66af89230026"
"id": "327d0dc8de88dfd4",
"type": "delay",
"name": "",
"timeout": "1",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"outputs": 1,
"x": 1120,
"y": 1120,
"wires": [
"faa5957d77558406"
"id": "43a9eb74610ec9d1",
"type": "change",
"name": "set fan speed 0",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "0",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1160,
"y": 720,
"wires": [
"325bf80ad4b65dda",
"2e255df180ef5c58"
"id": "ba87b75e6fefc6fe",
"type": "change",
"name": "set fan speed 1",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "1",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1160,
"y": 820,
"wires": [
"325bf80ad4b65dda",
"2e255df180ef5c58"
"id": "ee962ecd5962b9b5",
"type": "change",
"name": "set fan speed 2",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "2",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1500,
"y": 900,
"wires": [
"325bf80ad4b65dda",
"2e255df180ef5c58"
"id": "f88e5d8d8eeed8d7",
"type": "change",
"name": "set fan speed",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "3",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1740,
"y": 1120,
"wires": [
"325bf80ad4b65dda",
"2e255df180ef5c58"
"id": "40680816722e3848",
"name": "fan <2",
"version": 2,
"outputs": 2,
"halt_if": "2",
"halt_if_compare": "lt",
"entity_id": "LR/Airpuri3/Fanspeed",
"value": "",
"property": "data",
"value": "",
"x": 970,
"y": 1000,
"wires": [
"2946f6aada43ac55"
"53c8d37d0f904999"
"id": "53c8d37d0f904999",
"type": "switch",
"name": ">2",
"rules": [
"t": "gt",
"v": "2",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1140,
"y": 1040,
"wires": [
"b1f30937037c77cd"
"id": "b1f30937037c77cd",
"type": "delay",
"name": "",
"timeout": "1",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"outputs": 1,
"x": 1320,
"y": 1040,
"wires": [
