The Fiddler is done-ish... maybe. Hopefully.
I've made a few different versions ultimately making the palm-rest and adjustable part, so you can mod it to your own hand design. It does use about 10 M3 heat inserts to secure all of the components, which is a bit of drawback. If it works, it works, though.
Right now, this part is modeled for a right hand, but it can be mirrored for left handedness.
The highlighted blue component is the adjustable part for people needing to change it up for their palm.
![](https://cdn.hackaday.io/images/159301661046761492.png)
![](https://cdn.hackaday.io/images/5618881661046761467.png)
![](https://cdn.hackaday.io/images/5715541661046761511.png)
The prints are done, I just need to build it and put the build guide together.
I have now started to build the bracelet component of the Cyberdeck-B3. This component houses a hyperpixel display and a raspberry pi zero w2. I will try to make this comfortable/adjustable for people other than myself, even though I am using my arm as the base.
![](https://cdn.hackaday.io/images/7416231661046761535.png)
I made the stl model into a solid body by making a several planes and section analysis to draw a spline over that segment. Then I lofted all of the drawings together! Super easy, just tedious.
![](https://cdn.hackaday.io/images/5155441661046761529.png)
Gotta get all of this done and built before the cyberdeck comp is over!
Woot!~
Atltvhead
