Edit** The fix has been implemented and published in the following project log.
Edit* I just noticed the switches GND pins are wrong and would permanently ground the switch. Fix coming later, noted on this post.
Woo! Just finished the thumbstick pcb for the chorded keyboard. Again you can find it here on oshpark.
It has 4 of these switches and one of these thumbsticks.
