The build has officially begun! I am missing some M3 screws; however, I have the first ring on! I'll start cutting out the foam soon.
![](https://cdn.hackaday.io/images/4239571662837135273.jpg)
![](https://cdn.hackaday.io/images/238111662837135315.jpg)
If you noticed that the battery pack print is different, I am using Protopasta nebula. there was a small tweak to the cad of this part and that filament is what I had loaded.
