I designed the case using fusion 360.
I put the camera outside with some food to test it out and got these videos:
(the first 2 are fuzzy because I hadn't properly focussed the camera, but it is fixed in the others)
A raspberry pi based camera that records a clip whenever it detects motion.
record.pyx-python - 847.00 bytes - 11/16/2021 at 20:09 |
case top.stlStandard Tesselated Geometry - 122.64 kB - 11/16/2021 at 20:04 |
case main.stlStandard Tesselated Geometry - 142.17 kB - 11/16/2021 at 20:04 |
Awesome build and great results! It's amazing what we can fit into such a small enclosure these days.
great build, any chance you could share the wiring diagram?
