I designed the case using fusion 360.
I put the camera outside with some food to test it out and got these videos:
(the first 2 are fuzzy because I hadn't properly focussed the camera, but it is fixed in the others)
A raspberry pi based camera that records a clip whenever it detects motion.
great build, any chance you could share the wiring diagram?
