A dedicated card for the Raspberry Pi CM4-IO board -> PCI Express x1 to M.2 M-Key 2280 (PCIe NVMe) adapter
My first practical implementation of the PCIe x1 interface.Also the first attempt at the card edge connectors (gold fingers).Let's find out if this PCIe x1 adapter will work with the Raspberry Pi CM4-IO board...OK, the PCIe x1 adapter works smooth and easy with the CM4 module. Detected Kingston 256GB NVMe 2280 SSD drive.
View project log
Yes, delete it Cancel
You are about to report the project "PCIe x1 to M.2 M-Key 2280 adapter", please tell us the reason.
