The Chinese ISA manual is now complete! This is an very detailed instruction set manual drafted to resemble an 'official' ISA manual such as that of the RISC-V. The manual is meant to be easy to understand without being too long. Also, another feature of it is that it separates design from implementation. The Dragonfly ISA is designed to be implemented on different platforms, like TTL chips, FPGA, ASIC or even redstone! The manual also talks about how to expand the ISA. All of these means that you can create your own implementation of the ISA, with tweaks that you like! Well, if you can read Chinese... But don't worry, an English version of the manual is coming sooooon!
Jiajun Hu
