LoRa™ HAT for Raspberry Pi: LoRa™ HAT, a low-power consumption data transmission module, comes with an onboard CH340 USB TO UART converter, Voltage Level Translator(74HC125V), E22-900T22S and E22-400T22S SMA antenna connector, IPEX antenna connector, LoRa™ Spread Spectrum Modulation technology with auto multi-level repeating.
LoRa HAT For Raspberry Pi
LoRa® (Long Range) is the smart, long-range, wireless transmission technology that is enabling the future of IoT (Internet of Things).
Our IoT Gateway HAT with LoRa® allows you to create an inexpensive LoRa® gateway, compatible with The Things Network, in conjunction with a Raspberry Pi or other single board computers. The HAT allows you to set up your IoT LoRa® gateway in minutes rather than hours for a third of the price of traditional gateways.
Supported Frequencies
The HAT is available in two different frequency variations:
- 868 MHz
- 433 MHz
Check frequencies in your region? Click here.
Source Kickstarter
