Finally, now that everything came together for the NE555 logic flow, we can use it on an actual microprocessor. Above, you can see the result of synthesizing and placing the MCPU in NE555 logic. The MPCU is quite simple, it's an 8 bit CPU with only four instructions and optimized for small size.
Of course, any kind of discrete logic takes up a lot of PCB space and NE555 logic is a bit on the larger side. So even for this simple CPU we end up with a PCB that is about 200x200mm².
A 3D rendering out of EasyEDA above.
And one more.
The final microcell counts
ne_NOT 234 ne_WAND2 72 ne_WAND3 48 ne_TBUF 48 ne_WAND4 23 IO 20 __TBUF_ 8
Total component usage
Component Count pin 20 NE555 234 cap 234 resistor 287 diode 380 npn transistor 48 ------------------ ----- Total: 1203
I will not route and build the design for now, as I need to design a CPU testbed first. I have another NE555 design in preparation that I am planning to build first, but that will be in a different project.
Tim
