New update! Yesterday I finnished the dado cut for the legs. The cut is 10 cm wide and I startet making test legs to make shure the legs would fit and look good.
Dado cuts finished. Now lets put in the testblocks to se how it fits togheter.
Looks good altough I messed up the test leg. Goint to be carefull on the tablesaw when I cut the legs.
