There are 3 different toolchains and languages coming together in this project:
- Intel HEX file - there are innumerable systems and tools producing and consuming this old but still useful format, most notably all the assembler, cross-assemblers etc. in 8080/Z80 ecosystem on one side, and bunch of programmers, emulators etc. on others. Any can be used in combination with this project - as long as it is "old enough" (producing just 64k address space and 00 and 01 type records only)
- VHDL (using Xilinx ISE 14.7) - to compile it all together and generate a .bit file, standard FPGA toolchain flow. Few notes:
- No Xilinx specific "IP" components are used, in other words, "vanilla" VHDL could be recompiled for other FPGA vendors
- Lot of VHDL code is auto-generated by the microcode-compiler as a boiler plate to include and/or copy from to create the microcoded controllers
- Microcode - this is custom "language" I "invented" to simplify creating templatized controllers. There are 3 such microcoded controllers in this project:
- HEX2MEM - accepts stream of ASCII characters, interprets them as valid Intel HEX file stream, and generates memory write signals
- MEM2HEX - generates memory read signals, bytes read are assembled into Intel HEX file output ASCII stream
- TTY_Screen - accepts ASCII character stream (including some special characters such as CR, LF, CLS, HOME) and writes into a memory organized as MAXCOL columns and MAXROWS rows (in this project 80*60 for a text based VGA, but could for example be a 16*4 LCD etc.)
The software components are best explained by going through the 4 supported modes of operation:
-- SW7 SW6 Mode TTY (VGA) UART TX 7seg LED
-- 0 0 sel_hexout - Generated HEX mem2hex debug port (or bus if nWait = 0)
-- 0 1 sel_hexin Microcode trace Echo UART RX hex2mem debug port (or bus if nWait = 0)
-- 1 0 sel_loopback0 Echo UART RX Echo UART RX Baudrate (decimal)
-- 1 1 sel_loopback1 Echo UART RX Echo UART RX UART mode
See other project logs for description of each of these modes of operation.
