I started by using pliers to break up some safety pins (I have many problems with this name for these little abominations, by the way).
![](https://cdn.hackaday.io/images/9288961639019712039.png)
Having done that, I bent it into the correct shape and soldered in on to the board.
![](https://cdn.hackaday.io/images/3671661639019814012.png)
Then, I set in the next few in the shape of the battery, and marked the holes that I will use as contacts.
![](https://cdn.hackaday.io/images/384231639019917631.png)
![](https://cdn.hackaday.io/images/4514721639019917557.png)
And now it's time to make my solder bridges.
![](https://cdn.hackaday.io/images/374131639019991309.png)
Oh look, another picture.
![](https://cdn.hackaday.io/images/9689111639020020268.png)
Ok cool, now I can-
There I go again, solving nonexistent problems. I'll find a use for it someday, I guess.
Just don't set it on a conductive surface, with those contacts being used as legs...
