I started by using pliers to break up some safety pins (I have many problems with this name for these little abominations, by the way).
Having done that, I bent it into the correct shape and soldered in on to the board.
Then, I set in the next few in the shape of the battery, and marked the holes that I will use as contacts.
And now it's time to make my solder bridges.
Oh look, another picture.
Ok cool, now I can-
There I go again, solving nonexistent problems. I'll find a use for it someday, I guess.
Just don't set it on a conductive surface, with those contacts being used as legs...
