The heart of this project is the Geetech voice recognition module. In conjunction with an Arduino Nano and a relay, this little light-up Pylon can be voice controlled. The voice recognition module operating manual can be found here.
The operation of this design is very simple. You record a couple phrases, enable the voice recognition module, and when it detects a certain phrase, it will send out a hex value corresponding to it. In this design when "YOU MUST CONSTRUCT ADDITION PYLONS!" is detected, it will signal to the Arduino which will drive a transistor gate. This will power up the relay coil and complete the circuit to power the pylon. The phrase "My life for Aiur!" will disengage the relay.
William
Joe George
ivoras
I normally can't stand having extra "stuff" lying around the house, but I could see myself making an exception for this. Cool idea!
