Optimization part 1
A project log for NE555 buck converter
NE555-spiced buck converter
vedranVedran • 01/08/2022 at 20:34•0 Comments
The circuit kinda works, but it leaves a lot to be desired. There's 3 areas that I'd like to improve:
Baseline; Output (channel 1, top) trying to keep up with 5.1V reference as the input (channel2, bottom) increases from 6.5V to ~12V
Capacitances
I think the part where I can improve the most is tweaking input/output capacitances. So I grabbed all of my capacitors and started playing around.
Currently, my physical circuit features only one 10uF input capacitor and one output 33uF capacitor. So I set input voltage to 13V (well in the region where ripple is high) and started testing different capacitors. Trial an error (table below) gave 47u as the best available option.
Input ripple (VinPP)
Output ripple (VoutPP)Input capacitance (Cin)
3.4V1.4V10u
1.5V0.9V22u
1.7V0.9V33u
1.4V0.9V47u
1.8V0.9V100u
Or graphically
Noise on the output (channel 1, top) as the input voltage (channel 2, bottom) changes from 6.5V to 12V
