Main functions.
• Clock. Date and time indication.
• Management of aquarium loads up to 8 channels.
• Control of PWM loads up to 10 channels.
• Control of 2 internal fan channels.
• Management of up to 7 analog channels. (On development stage)
• Up to 10 daily timer programs.
• Up to 10 hourly timer programs. With a range of operating times up to 60 minutes.
• Up to 10 second one-time timers. With a range of operating time from 1 to 255 seconds.
• Up to 4 temperature timers.
• Support for 4 digital temperature sensors. on a 3-wire bus.
• Temperature measurement within 16 ... 35 degrees. Measurement resolution 0.25 ° C. The ability to control the load (heater / cooler) on any output channel. Under development: any channel including PWM and internal fan channels
• Battery for operating the microcontroller clock. Keeping the clock running.
• Automatic saving in non-volatile memory of all settings in case of complete power failure and battery discharge.
• Controlling the device through the touch screen.
• Information output to the LCD display 480 × 320 with minimal cuts, an intuitive interface.
• Communication with a smartphone on Android OS via Wi-Fi. Additional software for quick programming of timers, thermostat, time synchronization.
• Remote control of the device via Wi-Fi in the local network (or the Internet with a certain setting of network equipment).
• Self-synchronization and adjustment of the date and time of the device if the device has access to the Internet. Or remote synchronization via smartphone.
• The function of tracking the deviation of the readings of the sensors from the average set value with sound notification and indication of the emergency sensor. (During testing)
• Disconnection of the load (filter) by pressing one button for 5 or 30 minutes (temporary disconnection of the filter). (On development stage)
• Function of tracking and warning the water level (overflow). (On development stage)
• Function of tracking the PH of water, the implementation of PH timers. (On development stage)
Vadim Teselkin
Daniel
Kyle Gabriel
Juan Albanell
Arshia Keshvari
